Dale_Traveling
Jul 02, 2021Explorer II
MetalGator wrote:
,,,Is this a common problem?,,,
It can be a problem but having extensions should not be a reason not to inspect the tire for damage such as nails or a sidewall abrasion along with checking the valve stem seal and the extension. A little soapy water goes a long way with the confidence that the trip will be uneventful.
I've had two leaks. The valve stem seal that went while going down the road before I had a TPMS (destroyed the tire before I could get off the road) and a slow leak at the bead seal, post TPMS, after new tires were installed. Not had any problems with the extensions.
38,782 PostsLatest Activity: Sep 10, 2026
