H345
May 13, 2013Explorer
Your buyers inspection ( PDI ) Should take hours !
Every component should be cycled and the owners manual / documents should be accounted for and the person doing the inspection should have a ladder , flashlight , and a water hose . Your
AC cord should be plugged in and the generator fueled and cycled .
A binder / notebook should be started , and a small camera is useful for identification of some items .
A vehicle lift or a drive over pit should be used for the underside of the unit to check for exposed items , plumbing leaks , and routing of lines . Look for areas that need to be sealed - usually holes thru the flooring and walls are larger than necessary and will let moisture , bugs ,
and cold air in .
Vehicle should be weighed at all tires and axles to provide a starting point - the vehicle weights
listed in the brochure are general averages and not specific to your unit .
Notify your dealer of these requirements in advance - if there is any resistance , walk away ! !
and cold air in .
38,707 PostsLatest Activity: Jan 05, 2014
