bigdaddy51200's avatar
Oct 17, 2018
Install outside TV hookup on 2011 Breeze
I want to run a HDMI cable(HDMI splitter) from the bedroom to a bay under the awning for outside TV. Has anyone done this upgrade ?
I will be doing this upgrade for a blind friend on his breeze. I dont know much about this rig. I looked at it this past weekend and it look like the cables go down the left cabinet beside the bed to the bedroom tv, then in access block behind the bedroom tv next to the shower. It looks like it may run under the shower into living room slide underneath.
I would like to run a hardwire vs wireless.
    ????????????????????????????????????????????????????????. Tiffin does not make it easy to run cables(especially HDMI) on the Breeze models.
    Does this model have the Sat/DVD in the rear bedroom overhead storage behind the bed? If so, you could run it down the back cap and then up the chassis frame rail. Doug
    It does have the SAT/DVD in bedroom over bed.
  • Executive wrote:
    Not trying to be snarky, but wouldn't a radio do the same for your BLIND friend?? Seems like hooking up a TV wouldn't do him much good. Also, with a radio he could use headphones so as to not irritate or impose on his neighbors.....Dennis
    He uses his RV for tailgating at football games. He has a large group at his motor home. So he wants the TV where he can listen but everyone else be able to watch. I'm just trying to help him because he can't do this himself.
  • Not trying to be snarky, but wouldn't a radio do the same for your BLIND friend?? Seems like hooking up a TV wouldn't do him much good. Also, with a radio he could use headphones so as to not irritate or impose on his neighbors.....Dennis
  • I will be doing this upgrade for a blind friend on his breeze
  • if any base cabinets on that side take out the bottom drawer and see if you see it. Just seal the holes after you run the cable where every you have to drill a hole.
