GordonThree
Jul 15, 2018Explorer
jarata1 wrote:
I just installed a t on my propane tank on the motorhome so i can hook up my grill and fire pit here is my problem
To go under the motorhome I need more then 12 feet and cant seem to find a hose thats over that with a 1 inch male and 1 inch female
Also my propane fire pit doesnt come with a regulator so i would need a longer hose with a regulator with the 1 inch connections
Go see Hank Hill or one of his colleagues at the propane store, they'll make you whatever kind of hose you need if they don't have it in stock already.
Is your T on the high pressure (tank side) or low pressure (appliance side) of the existing plumbing?
If you're T'd into the low pressure side, your fire pit won't need a regulator, just a needle valve to control the flow, same for the grill. If you're on the high pressure side, things are more interesting.
