wa8yxm
Jul 16, 2018Explorer III
Caping world and most RV stores will have "Extension" hoses, 10' long. male and female "Quick Connect"
is the fire pit designed to use those Disposable bottles. if so it has a regulator.. If it's designed to use a luggable tank. then the regulator may be on the end of the tank hose. (You can get an adapter at the above stores to connect the quick connect hose to that regulaator as well).
Post photos if you want me to look up links to samples of products.
Specifically the fire pit hook up and hose. as well as the T.)
