wa8yxm
Jul 16, 2018Explorer III
Yes the fire pit will need "Some kind of regulator"
I do not like that adapter pictured above. I like the Extend-a-flow. or "Stay-a-while"
This is the modern version (ACME as well as POL for the hose to the RV) adapter I use
Extend-a-stay
The large side connector is a "Quick Connect" like the top of a throwaway bottle.
Hose connects to it. then to the reguator on my grill.
If you have a Regulator with a connection for a luggable bottle (That is the connneciton on the right on the diagram... which is where the RV/s existin propane screws in)
THen The Camco 59213 1lb Propane Bottle Adapter or one like it is what you want
See it on Amazon
Extend-a-stay
See it on Amazon
