CA_Traveler
Jul 16, 2018Explorer III
jarata1 wrote:OK Let's be clear on what you have.
the fire pit has its own regualtor on it and connects to a 20lb tank what i want to do is work of my t on the motorhome not sure of the connection plus i would think it needs some sort of regualtor
1. Do you have the 1" connector on your T - the same as my picture above?
2. And your pit has a regulator with standard 20 lb propane connector? ie Your original post said no regulator.
If so buy the propane hose with 1" male/female ends and the adapter John posted above. There is now one and only one way to connect your T to your regulator.
Additionally if you have a BBQ that uses the small propane bottles then you can also connect it to your T.
