Gjac
Sep 07, 2020Explorer III
I had the same issue several years ago took it to a front end shop when out west they told me that the noise I was hearing was from the spring not being seated properly, the reseated the spring charged me $330. About 100 miles later in Wyoming I started hearing that noise again thinking it was the spring until my LH ball joint failed and the whole front end collapsed. I was making a left turn to get on the hiway when it happened. The second time it happened was in Mt. the following year going 60 mph around a curve and the rh ball joint failed with out any noise or warning. The shop back home installed the wrong ball joints twice. What were the ball joint part numbers you installed? I would hate to see this happen to anyone else especially coming down mountainous roads out west it would be fatal.
38,782 PostsLatest Activity: Sep 10, 2026
