Executive45
Jun 26, 2015Explorer III
Ivylog wrote:
I bought a Whirlpool WRT771RWYB 21 cu ft refer as I hoped it was short enough to fit in the hole of my NoCold 1200. Cutting out the board at the top that holds the 1200 in still left me 1/2" short on the needed height of 65 1/2". The DW did not want to give up the large drawer under the 1200... So I cut out the 3/4" plywood floor and put in side rails for the edge of the refer to sit on. Sorry but I do not know how to rotae pictures on my Iphone.
Filled in the bottom with 2 pieces of 1/2" foil faced insulation that I had behind the 1200. Added four steel angle brackets at the front cross piece to help hold the weight of the refer that cantilevers 6" out from it. Not shown in this picture.
I've had my 1200 out so many times it's something I do by myself using a platform to slide it out on to and then I can slide it to the floor and then walk it out of the way or in this case, up front. Was able to get the 1200 out the side window without the four doors on and putting two boards over the coils/fins so I could slide it out on it's back. Used the 3/4' scrap plywood on top of the steering wheel to help slide it out. With some help from my John Deere skid steer I was able to get it out by myself.
Getting the new on in took some help from the DW to get it to slide in without hurting the driver's chair. Getting it into the hole took some effort as it's a tight fit, but we got it to go.
Without the passenger's side LR slide out the bottom door will not open all the way. The driver's side slide comes in the same amount as this new refer stick into the hallway so other than the door not opening all the way when traveling, I'm happy with how it's turned out and I did not have to modify the drawer under it.
Welcome to the "Formerly known as Norcold Owner's Club"...Dennis
38,782 PostsLatest Activity: Aug 30, 2026
