Hoerschel's avatar
Hoerschel
Installing After-market Rear View Camera Issue
I recently bought a Four Winds 28A from Cruise America and attempting to install a highly rated wireless rear view camera. Upon drilling into the back wall I discovered a layer of sheet metal that apparently is interfering with the wireless signal from the camera to the monitor in the cab. The manufacturer of the camera has offered to send me a booster antenna with 13' cable to install on top of the rig and closer to the monitor. However, I'm still concerned the metal layer is going to interfere. Has anyone had this experience and any recommendations? I'm trying to avoid installing a wired unit due to the extra level of work involved.
  • Use heavy duty tape to temporarily mount the camera while you check the signal but I too believe wired is better.
  • I was always told that metals do interfere with a wireless camera signal. Sometimes mounting the camera off to the side will work but you have to try that without drilling more holes.
    I found wireless things to be a PIA in general and prefer wired products.
