Johno02
Oct 15, 2017Explorer
Check you entrance door to find our how think your walls are. The ourside is basically pressboard, with a foam block inside. So your only holding area is the thickness of the outside panel, about 1/8 inch or so. Screws shorter than the thickness of the entire wall. Most RVs do not have any wiring or plumbing built into the walls like houses do. The walls are generally prebuilt laminated panels, with all the wiring inside the coach. Some wiring may be in the channel where the walls and roof are joined.
38,769 PostsLatest Activity: Jul 09, 2020
