RoyB
Aug 01, 2015Explorer III
This is what I did mounting antennas on the side of my 5th wheel up near the roof edge using the trucker mirror mount hardware. This is NOT the Sirius antenna but rather a Ham Radio 2M/440 antenna. As long as you can get the Sirius/XM antenna extending above the roof line it should do ok...
As you can see the mounting groves really worked out for me to guide the RG cable away from the main body and also to cover the small hole drilled into the side of the roof area. This area was picked as there was a ceiling cabinet on the other side of the trailer wall where the RG cable ended up at. Then it was easy for me to route to the radios's inside the trailer.
After the RG cable was routed into the trailer than I filled the groove area on the outside mount plate with RTV sealent.
The 8 mounting screws you see in the photo are just self tapping type metal screws only to the outside wall area.
Hope this might give some ideas in your installation if you decide to go for the TRUCK MOUNT SIRIUS/XM ANTENNA shown here..
The second photo might be better for doing this which is available from AMAZON...
ADDED NOTE: Just remembered I saw a SIRIUS/XM round antenna mounted on top of the FRIDGE FLAT PLASTIC VENT section on the roof of a trailer once - That would be another easy mount location... Sorry couldn't find a photo on google showing this.
Roy Ken
Roy Ken
38,782 PostsLatest Activity: Aug 31, 2026
