LI-Camper
Aug 19, 2015Explorer
Hi All, I'm the OP. I used a highly skilled installer to get my SiriusXM Ready Jansen radio to work. He had to take the whole dashboard apart to get the radio out. The SiriusXM module plugs into the radio and the antenna plugs into the module. Both come in a kit from Amazon (SXV300) for about $37. The installer put the antenna on the cab roof (attached by its magnetic base) beneath the cab over. He ran the antenna wire to the gasket that holds the windshield in. No holes were drilled into the roof. The antenna worked well on a trip to PA and back to Long Island. After seeing what is involved in getting the radio out of the dash, I would recommend a experienced installer to handle the job. The steering wheel column has to drop down to remove part of the dash!
38,782 PostsLatest Activity: Aug 31, 2026
