lfeather's avatar
lfeather
Intake manifold temperature creeping higher
I have been noticing that my manifold temperature has been creeping higher on my ISL 370 w/80K miles. It used to be 10-14 degrees F higher than ambient temperature. But now I'm seeing (via Silverleaf) 18-20 degrees higher than ambient temp. Fuel milage is decreasing too. Ambient temp today was from 88-92F. Anyone have any insight of possible causes? TIA
Larry
  • Thanks for the inputs. I'm going to try changing the air filter and see what that does. It's been a while since I changed it. Indicator looks good but, I'm told unreliable. Also have noticed increased black soot on tail pipe
    Larry
  • Yup, blockage of air flow through the CAC is the most likely cause.
    With a side radiator, could also be that the hydraulic fan or fan control is failing to provide needed RPM. But, that would normally also lead to higher engine coolant temperatures.
  • How clean is the charge air cooler (CAC) and has the engine coolant temp been holding at normal average?
