wsqr
Apr 29, 2013Explorer
I've got a lot to learn (relearn?)on this new rig. Trying the complete power down route tonight. Had no idea, and still don't if there or where a master house battery switch is located. I expected to find it under the step with the house batteries but no. Next I looked on the electrical shelf located with propane tank, no luck there but saw several warning stickers to disconnect batteries before opening covers. So I disconnected the negative battery to house connection. I have two 6v's, I left the pos / neg battery to battery cable and the positive terminal to house cable connected. I only disconnected the negative to house. Shore power unplugged. The engine battery was not touched, it is still connected and the power step works but no coach lights will switch on so I'm thinking the step is on the engine circuit. I'll see what happens tomorrow when I get home from work and reconnect. Batteries first then shore power. If I should also disconnect engine battery throw up the flag!
38,774 PostsLatest Activity: Apr 26, 2026
