dougrainer
Jun 11, 2013Nomad
Measure BETWEEN the 2 hot legs. IF you get 230/240 volts, your EMS is malfunctioning. IF you do NOT get that voltage, you are NOT on correct 50 amp service. You are on cheated 50 amp which is on the same phase. True 50 amp is out of phase. The EMS "sees" the 2 separate phases and that is how it knows you are on 50 amp service. Doug
38,766 PostsLatest Activity: Jan 10, 2026
