mscamping
Jun 11, 2013Explorer
First make sure all breakers are closed, even if there not in use.. Second, I'd say the shore power is using two parallel 120 volt circuits, and they show up as 30 amp on the panel.. Check voltage across the two hot lines and you should get "0".. This has happened once or twice to us.. You should be OK since you don't have any 240 volt stuff.. Mike Mathews..
38,766 PostsLatest Activity: Jan 10, 2026
