wa8yxm
Jun 14, 2013Explorer III
dougrainer wrote:
BOTH of these posts are not correct. There is NO WAY an Intellitec 50 amp EMS will show anything other than 50 amp service if on TRUE 50 amp service. If the Intellitec shows 50 amp,
1. YOU CANNOT change the service to 30 or 20
2. The AMP readout will NOT be on.
There are basically 3 ways you can plug into 50 amps and the Intellitec will say "30"
One: Park is not properly wired, you have L-1, N L-1 (or L-2 N L-2) this not proper 50 amp service and in fact is a fire hazard.
2: Defective Intellitec
3: Other defective part or tripped breaker feeding it.
(Oh, and 4, forgot this one,,, Someone messed with the order of breakles in your box and put both lines to the EMS on the same leg)
38,766 PostsLatest Activity: Jan 10, 2026
