My first glue of choice for MOST projects is GOOP. it comes in assorted flavors some have greater chemical or UV resistance.. however it's not as "Solid" as say Epoxy it retains a bit of "Stretch" when dry and this can lead to failure in a bouncing down the highway sort of way.
That said when I needed to re-stick some felt under the floor of a slideout that had come loose. My Service tech had to pull hard to peal the end off where I'd tacked it with goop. and when I spread a bead and pressed it down she said "how long to dry" I replied book says 30 minutes but 5 should do it.> Well it was perhaps 10 later when we put the floor back on top and 30 before we moved floor.. IT IS STILL where I stuck it not going anywhere. The 2-faced tape Damon used is nothing compared to Goop.
AH at last Rasperian has finished downloading.. (Another task).
