Grillmeister
Jun 12, 2013Explorer
Executive wrote:X2. Also be sure to check the connection on the starter too. Mine was bad once and you could see the connection was black from heat and resistance.
My money is on a bad cable or ground...most likely on the starter batteries. Remove the cables, one at a time, clean em, lube em and reinstall. Let us know if that fixes the problem....Dennis
38,783 PostsLatest Activity: Sep 22, 2026
