Ro646a
Jun 13, 2013Explorer II
I went out this morning and it acted dead again when I turned the ignition key. So I hit the aux start switch and it started right up.
Then I turned it off and tried starting it with the chassis battery and this time it cracked right over as normal and started right up.
I checked the chassis battery voltage and it is 12.7 and all of the visible wiring and connections up front and clean and nice as new. I suspect that the issue, as some of you suggested, is a bad connection at the starter, since occasionally it acts the same way when using the aux start switch.
I can't get to it today, but as soon as I check this out I'll report back to you.
Thanks for all the helpful comments.
Roland
Roland
38,783 PostsLatest Activity: Sep 22, 2026
