darsben1
Sep 26, 2016Explorer
Operating The Freedom SW 2000
OFF Mode
You can manually transition the Freedom SW 2000 to OFF
while in Invert Mode by pressing the ON/STANDBY switch once. In OFF Mode, no indicator lights are illuminated and the display screen shows blank.
Once in OFF Mode, if qualified AC power becomes available then the unit
automatically starts charging. However, when AC becomes unavailable, the
unit will not transition to Invert Mode until the ON/STANDBY switch is
pressed once.
Then put a light on various plugs till the bulb illuminates
OFF Mode
pressed once.
38,766 PostsLatest Activity: Jan 10, 2026
