wa8yxm
Sep 27, 2016Explorer III
Koo-B-Yon wrote:
In speaking with another Winnie owner tonight during a power outage, he mentioned that his TV was running on the inverter during the outage. My Question: are there special outlets that are designated to supply 120V when no shore power is on, and if so, Where, oh where can they be? I have a Freedom 2 Kw inverter, but have never found anything that it does, other than charge the batteries. The inverter was changed out about 2 years ago, but I never noticed if it was any different before then.
While I do not yet know if the Freedom is like mine.. I know my inverter has the ability to be "Turned off" I can set it as follows:
1: OFF: Nothing passes, it will not even pass power to outlets
2: ON but non operational. Both Inverter and charger disabled. It will pass power to outlets, but will not invert or charge batteries
3: inverter on (Standby/Operating auto switch) in this mode it will pass power IF present or invert (make 120 volts) and send it on if needed
4: Converter/charger on (makes 12 volt out of 120 volt shore/generator power)
5: Both 3 and 4
You may have the inverter disabled. BINGO this is from the owner's manual:
97-0019-01-01
15
Freedom Inverter/Charger Operation
Start Up Behavior
When the Freedom SW is powered up
or has been reset, all of the
front panel LEDs turn on and remain on for a minimum of five
seconds. During this interval, the fans are also turned on as the unit
executes internal diagnostics.
Out of the box from the factory,
when the Freedom SW is powered
up (that is, when AC and DC powe
r sources are connected) for the
first time, the inverter function
is disabled by default. After
powering up, the
INVERTER ENABLE
button (or the “Up” button
on the SCP) can be used to enable or disable inverter function. See
“Inverter Operation Using the Front Panel” on page 16 and “Enable/
disable inverter function (
Instructions can be found on page 25.
38,766 PostsLatest Activity: Jan 10, 2026
