usersmanual's avatar
usersmanual
Inverter 3000 question
Just Installed a 18Cu FT Frigidaire in a 2008 AB and I have a xantrex 3000 inverter system from the factory
It runs great on the inverter system and my question to anyone whom has experience is when the batterys run low and the inverter power drops below acceptable voltages needed to run the fridge what happens
? does the inverter shut off or exactly what protects the fridge from compressor damage from low voltage?
This question only relates to a ""what If"" situation as I plan to make sure this situation does not occur
  • Mine is set to alarm at 11.5 and shut down at 11.0. I should note that I have the ProSine from Zantrex if that makes a difference.
  • Some are set to around 10.5. I suppose if I had the tool I'd probably put that up to 11.5.
  • bluwtr49 wrote:
    I also have that inverter. There is a low voltage setting that shuts off the inverter when the battery voltage reaches or drops below that setting. The setting is also user adjustable if you have the advanced monitor panel.
    thanks a bunch I will look at that setting system for sure
    much appreciated
    what would the factory setting most likely be? and whats a safe level(lowest one would go) with out worry of Battery damage
  • 2oldman wrote:
    It's my understanding the AC output never drops with battery voltage.. it just quits.
    you know I never thought of that.I know a lot about motor homes but honestly just never hardly used the inverters over the years
    that would make sense for sure
    Thanks
  • I also have that inverter. There is a low voltage setting that shuts off the inverter when the battery voltage reaches or drops below that setting. The setting is also user adjustable if you have the advanced monitor panel.
  • It's my understanding the AC output never drops with battery voltage.. it just quits.
