pianotuna
May 27, 2013Nomad III
Hi,
There is a fuse between the alternator and the "house battery" charging circuit. Replace it. Or do as I did and go with an auto reset circuit breaker. I did that after two fuses popped. The fridge draws about 30 amps @ 12 v dc. My microwave draws 160 amps @ 12 v dc. The fuse is often only 60 amps.
The 60 amp fuse is in the engine compartment fuse box--not in the "house" fuse box.
38,771 PostsLatest Activity: Apr 15, 2026
