CA_Traveler
May 27, 2013Explorer III
TobyRHudson wrote:With 12V to the inverter then it's not a fuse between the battery and inverter. Plus the AC output works on the gen so the ATS in the inverter is OK. This points to an inverter problem. Are there any fuses on the inverter?
Am still getting 12v to the inverter. Didn't know about the fuse in the engine compartment. I think that may be the answer I was looking for. Where did you install the breaker you replaced the fuse with?
Also are the batteries being charged? This would indicate that the AC wiring to the inverter and DC charger portions are OK.
38,771 PostsLatest Activity: Apr 18, 2026
