CA_Traveler
May 27, 2013Explorer III
I know Don but he has 12V to the inverter and no AC output. However point taken if he has 12V with no loads then he might have a charging problem which is not allowing the inverter to run.
OP Did you use a reasonable accurate voltmeter and was it measured under load?
38,771 PostsLatest Activity: Apr 15, 2026
