pianotuna
May 27, 2013Nomad III
Hi Toby,
It is installed with a faux fuse with leads going to the auto reset breaker secured to the lid of the fuse box.
CA is quite right I do have a much larger battery bank than most--but even with that I was blowing the OEM fuse which was rated at 60 amps.
CA is a knowledge member in this area and you should listen to what he is saying. It is possible that there are breakers needing resetting on the inverter, too. One may be needing a reset--which might explain why you have no output to some areas of the RV.
Is the inverter working at all? I.E. will it run anything in the RV?
TobyRHudson wrote:
Where did you install the breaker you replaced the fuse with?
38,771 PostsLatest Activity: Apr 15, 2026
