TobyRHudson
May 28, 2013Explorer
No problem with the batteries charging. With no power source other than battery the inverter converts the battery power to AC however the fridge will not run off of this. It does see enough power from the inverter, in this mode, to run off of propane. No power to the microwave or an outlet by the microwave. In this situation the inverter shows both input and output voltages. When running the engine though, the inverter shows only the input batter voltage and no output voltage. I checked the fuses under the hood and the only one not listed in the OEM manual is a 20amp and it shows to be good. Do you think the factory would have installed a fuse elsewhere? The inverter has a breaker on it but doesn't seem to do anything (like it's not tripped). Resetting it is really the only thing the manual refers to when troubleshooting. Don't see anything in the manual about resetting the system. I'm a pretty handy guy but, am new to the RV world. I appreciate ya'lls input and patience.
38,771 PostsLatest Activity: Apr 15, 2026
