pianotuna
May 28, 2013Nomad III
Hi,
The fridge only draws about 325 watts. It should run easily from the inverter.
How is the inverter output connected to the 120 volt power supply on the RV?
Is the converter turned *off* when you are attempting to run the RV from the inverter?
TobyRHudson wrote:
With no power source other than battery the inverter converts the battery power to AC however the fridge will not run off of this.
38,771 PostsLatest Activity: Apr 15, 2026
