pianotuna
May 29, 2013Nomad III
Hi,
I'd try by passing this transfer switch, or checking to make sure it is working.
What make and model is the inverter?
Does the converter work when on the inverter power?
Many of the systems on an RV run on twelve volts--such as the water pump. Please read this web page to get a "handle" on those items:
http://rvroadtrip.us/library/12v_system.php
TobyRHudson wrote:
I should have added, there is a transfer switch mounted next to the inverter.
38,783 PostsLatest Activity: Sep 22, 2026
