Hi guys! Why does my on board inverter fail to allow my tv to turn on? New rv. Dealership told me it should so we can use the tv while driving without using the generator. Any suggestion?
Get a small lamp, or even an electric tester for 120 volt. Turn on the inverter. Use the lamp or tester and test every outlet to see which ones are powered by the inverter. Plug TV into outlet powered by the inverter to see if it will operate on inverted power.
