time2roll
May 26, 2021Nomad
If you have a voltmeter you can plug in overnight and check. 13.2+ volts on the chassis battery is getting a charge. 12.6 volts or less is not getting a charge.
You can add a battery combiner, such as Trik-L-Start, that will send power from the house system to the chassis battery. The combiner will separate the batteries if you are not plugged in.
A 20 yo MH may have had something installed by a prior owner. Check it.
