dons2346 wrote:
If you look at iMarineyou can get the 2812 for $1,405 and the 3012 for $1,058. iMarine is the cheapest place to pick up an inverter.
There is no real need to go up in inverter size because of the refer. Depending on the brand of refer will determine whether you need a sine wave or if a modified will work. Samsung can run on a modified no problems.
I think the price difference is worth it. Your microwave won't groan like it does with a modified. All your wall warts will be happier also.
Thank you so much for the information, I ordered the 2812 from this company you mentioned and saved a lot of money!:B
