msmith1199
Mar 26, 2016Explorer II
Tkotis5 wrote:
I'm wondering if you have one do you get a lot of use from it? Will a dealer install it and at what cost? Can you shut off your dash board air and run your ac off it? Do most units come with it installed?
My motorhome came with a 2000 watt inverter. And yes, I get a lot of use out of it. Without an inverter you can't run TV's or other appliances without being plugged into power unless you have 12 volt TV's. My inverter will run everything electric except the A/C's and the Fridge. It may actually be able to run the fridge, but they wired the RV so the 120 volt outlet the fridge is plugged into won't get power from the inverter at all. The A/C's also are wired so they can't get power from the inverter. I don't think 2000 watts would be enough to even start the A/C's.
38,782 PostsLatest Activity: Sep 10, 2026
