supercub's avatar
supercub
Inverter for Residential Frig ????
First off, I don't know if I have a pure or modified sine wave inverter. Yes, I will find out. However, for now, lets assume I have a modified 2000 watt inverter in my motorhome.
1. If I install a residential frig that needs a pure syn wave, can I install a second invertor that is devoted to just the frig? I ask this, because I'm assuming buying a smaller invertor would be much cheaper then replacing my 2000 watt invertor which runs fine.
2. If you can run a second inverter, can you run it off the same battery bank that runs the 2000 watt existing inverter? I have 4-6 volt batteries.
3. What size invertor would I need to run a residential frig?
Thanks
Brian
