JCMack's avatar
JCMack
inverter question
Just purchased a 3000 watt modified sine wave inverter for my motor home. We have two led TV stereo equipment and computor equipment. I am now being told that I must have a pure sine wave inverter for the equipment to operate with out problems. Can some one shed some light on which inverter in the correct one to use. Thanks
  • Some of the older switching type power supplies used to not like modified sign wave inverters, however most modern switching supplies don't care. They used to be confused by the noise generated by the abrupt switching. Modern designs are more stable and not screwed up by the noise.
  • Almost all electronics work well on modified sine wave inverters. Especially things with adapters.
    Things such as a/c powered cordless drills, saws, and a/c motors - plus certain types of lights should be on pure sine.
  • Hi Tom,
    I'm glad to hear you don't have a problem--but many folks *have*. I'm not a Mac user, so I don't have a horse in this race. I have used MSW for 13 years but recently moved "up" to a 3000 watt pure sine wave hybrid Magnum unit.
  • pianotuna wrote:
    Hi,
    3000 watts is overkill for entertainment center equipment. Some televisions don't mind modified sine wave. Others do. In your shoes I'd add a 2nd inverter that is pure sine wave and about 300 watts.
    Most computers are "ok" on modified sine wave. The exception is Apple. Using them on an MSW inverter lets out the magic blue smoke from the computer.
    My iMAC works great on my modified type inverter/charger.
  • I have the MSW Xantrex 458 3000 watt inverter and it works great for TV, Computers, coffee makers and even the Micro wave.
    That's a pretty big inverter and hopefully you have the battery power to sustain and do it justice.
    As for the wave, we have a mod sine wave 1000w running on two 6v batteries and use it for two LCD/LED tv's, a DVD, a laptop, and the fridge with no problems due to the wave form. Just won't last long with the fridge, dry camping and use it mostly for going down the road. If we had some of the ice maker, etc...accessories on a residential fridge, then the electronic circuitry associated with that, may not like the mod wave. As for size, we could do it all with a 750W, easily and have been known to make a big pot of coffee <900W with the 1KW. If you feel the need for a pure sine wave inverter, it will cost at least twice as much and maybe more expensive for a 3KW. We just replaced the 1000w we had after almost 6yrs, with an Auto Zone model for $100.
  • Hi,
