supercub
Mar 26, 2015Explorer
inverter question
Do you leave your inverter on after turning off the TV for the night when dry camping or do you, or should you turn the inverter off.
tahiti16 wrote:
I only turn on the inverter if I need it to power something as it has it's own parasitic load on the batteries even when nothing is calling for power. Can be from 1-5 amps depending on the inverter.
