Mlewin51 wrote:
I noticed though that the inverter is 750watt that only goes to one outlet in the bedroom. The inverter is under the bed along with the breakers for 110 service. Can't I junction box the inverter nomex 14-2 and tap it into the 14-2 AC line for the TV? I'd like to run the inverter while driving for tv usage without running the generator.
Cheers!
Yes! Just get a small transfer switch and connect to the branch circuit that feeds the entertainment center.
http://www.donrowe.com/KISAE-TS15A-Automatic-Transfer-Switch $50No need to pull wire or mount extra outlets. Just make connections.
