Mlewin51's avatar
Mlewin51
Inverter question
I have a 2006 Damon class A. Recently purchased. We love it and will be fulltime shortly. I noticed though that the inverter is 750watt that only goes to one outlet in the bedroom. The inverter is under the bed along with the breakers for 110 service. Can't I junction box the inverter nomex 14-2 and tap it into the 14-2 AC line for the TV? I'd like to run the inverter while driving for tv usage without running the generator.
Cheers!
  • I would just run an extension cord from the inverter to the TV. How are you going to get reception on your TV?
  • Yep good point, I can always incorporate the breaker into the junction box. Just switch it off prior to plugging in shore power
    Cheers!
    I would run it through a breaker. The breaker would be a manual transfer switch so you don't accidentally put shore in the "wrong" end of the inverter. Not sure how that would affect your inverter but I expect it would be bad!
