LongWeekends wrote:
Bill.Satellite wrote:
Auto invert means that anytime the coach loses power the inverter will kick in an power those 120V outlets to which it is attached.
Just re-read this. So not every outlet in the coach is necessarily hooked up to the inverter?
So....if I am not plugged in and not running the generator BUT the inverter is set to "auto" I still might not see power at every outlet, correct?
You are correct - chances are the inverter output is only wired to some of your outlets. I have a Tripp-Lite setup just like this one by the way. I have to remember to turn my fridge to GAS instead of AUTO when my inverter is running the coach off batteries, as the fridge draws a lot of current.
