wallynm
Mar 03, 2016Explorer
Not sure what you mean by "click right over" but there is a built in delay. Try starting the generator and see what happens without doing the tapping routine.
toban wrote:
I have a DSDP Newmar. I have noticed when I start my generator, the transfer switch clicks after starting but it doesn't click right over for a contact. I lightly tapped the top of the box and it clicks further to make a contact. I shut down the generator and started it again to activate the transfer switch again and it clicks right over.
What does one do to fix this situation? Can you clean or lubricate the swivel points inside? It doesn't take much to have the contacts come together with a light tap on top of the box. As I said, I've repeated this process over and over and it clicks right over after the initial tap.
Any suggestions for me?
Toban
38,782 PostsLatest Activity: Sep 10, 2026
