Corkey05
Mar 04, 2016Explorer II
Toban ... Any power to your coach has to go through the transfer switch. The switch decides when to move the source to generator or shore power. So, if you use the coach, you use the switch.
The only time it's not in the loop is if you're running on Inverter (if you during boondocking).
It might not be your problem, but it's a known problem with a known safety issue bad enough for an industry wide recall.
38,782 PostsLatest Activity: Sep 10, 2026
