ViaSteve2015
Jul 18, 2021Explorer II
Damon was bought out by Thor quite some time ago. As stated above, it was an entry level coach. There's nothing wrong with that, but you should just learn as much about the coach as you can in terms of how it was constructed and what components were used.
If considering a MH in that age bracket, the more important factors are condition and service records along with determining what price items may need replacement or repair. If everything is original, you have to expect that there will be some expenses. Then you have to decide whether it's still a good purchase or would you be better off buying something newer or that has had more renovations.
There are no easy answers. You have to learn as much as you can about every aspect of a motorhome, from the chassis, engine/transmission on up to how the "house" is constructed and equipped. And, prior to purchase, getting the rig inspected by a professional is definitely something to consider unless you have a lot of expertise on RVS.
Good luck in your search!
38,782 PostsLatest Activity: Sep 02, 2026
