FIRE_UP
8 years agoExplorer
kars wrote:
THank you all for your responses, for some reason I really thought an A gasser would be smoother
I will contact dealer to see what they have to say and maybe they can help with the tire pressure, we dont carry anything but 5 little doggies and 2 adults.
few crates
I will try to empty the water tank from now on if I know I am going to a place with water as I dont want to pay gas to move water slushing around.
thank you again , I have learned a few things and will ask on the class C too.
That would be your first mistake. About 98% of dealer salesfolks are absolutely clueless about what they sell. Many folks on here and other RV forums have been mislead in many aspects of their RVs, how to use them, how to set them up, how things work etc. The folks that use them are the ones to ask.
You're wasting water by dumping it out. There are many that think by running around with a 1/4 tank of water is going to reap big benefits in the mileage department. Well, I'd bet Trumps salary that you won't see one mpg difference. And, what happens if you need that water for ANYTHING? You could get stranded or a break-down of some sort could cause you to have to stay someplace 'till you get fixed and you'd need that water. This is all a matter of choice.
Our coach, an '04 Itasca Horizon 36GD with the C-7 330HP CAT, get's 6-7 mpg, with an EMPTY WATER TANK and a full one. It gets that mileage with an EMPTY FUEL tank, as well as a full one. It is no faster in performance with an EMPTY WATER TANK than it is with a full one.
Now, as far as the ride is concerned, well, that's a matter of each individual coach, it's tires, it's suspension and more. We just got back a week ago, from a 6,400 mile trip, around the entire U.S. And, without a doubt, it wouldn't matter what kind of rig you drove, there was much of that trip that jarred out teeth out and we don't have DENTURES!! Michigan takes the First Place Trophy for the worst roads we hit, in 20 states. I run the tires at the prescribed PSI, based on the tire pressure chart of the MFG of the tires, size and weight of the coach.
And, about what, 95% of the Class A gas chassis coaches are on F-53 Ford Chassis. Those have been touted as one of the worst riding gas chassis's. Now, not all of them are that way. It depends on how they're loaded and other factors.
But, in all reality, the smart thing to do is, go to either an RV show where there's plenty of all types to choose from. You won't get a good feel for the ride as most of those will be empty but, you'll get the basics. Next, talk to folks at campgrounds. We've done that zillions of times. About 99.9% of people at most campgrounds are happy to talk about their rigs and experiences. And that includes admitting the bad stuff too.
We've had two Cs and two As. BAD ROADS affected them all. You could have the worst riding coach on the planet but, if you're on a smooth, well done road, then the ride is the same as a very high dollar diesel rig. Smooth is smooth. It's how well the ugly stuff is dampened that makes a difference. Good luck on your search.
Scott
38,778 PostsLatest Activity: 5 days ago
