Sam_Spade
Aug 30, 2017Explorer
kars wrote:
I will contact dealer to see what they have to say and maybe they can help with the tire pressure,
There should be a label/placard somewhere around the drivers door that has the recommended tire pressures on it.
That should be considered minimum pressures.....but they should work fine in the majority of circumstances.
AND......how old are your tires ?
They tend to dry out and become somewhat hard with age, no matter what you do to "take care" of them.
They usually should be replaced around 6-7 years even if they look good.
P.S. I just switched from a large C to a "small" A. The "ride" seems much better with the A BUT that comes at a price; there is a lot of "sway" if you hit a big bump with only one side of the duals.
38,778 PostsLatest Activity: Jun 10, 2026
