afrescopXx
Oct 28, 2015Explorer
Is it the chassis or coach?
Recently I noticed that when I attempted to activate the high beams by pressing the turn signal stalk forward the headlights turned off. I then discovered the "flash to pass" feature activated by pulling back on that same stalk was not working. Since my Itasca is on the Ford F-53 chassis and still under their warranty I took it to a locat Ford dealer. The service writer brought their electrical "expert" out to look at my coach. He declared the problem to be in the coach and not the stalk switch. The "expert" stated that since turn signals and wiper/washer, all on the same stalk, were working it wasn't the switch.
Here is one more thing. As I was backing the RV out of the storage place my wife told me the rear passenger side brake light was not working. When we returned from the Ford dealer I removed the lens to access the bulb. The light fixture contains two bulbs. I replaced the bulb only to discover that the brake and turn signals on that side still are not working. The other bulb works as it is supposed to as a tail light. The front passenger side turn signal bulb is also working.
I believe the "expert" is incorrect and both items are connected. Any ideas?
