labguy1963 wrote:
Yes, just me and my dog. Not a lap dog, but a lab. Labs need room and so do I. It wouldn't be a MH for a leisurely drive to the local state park for an overnighter. I do plan on being in one for quite a spell since I want to go to the eastern TN or NC area to seek work and a better life and this MH or similar would at least a place to hang my hat. I should have the real scoop tomm and I will see if I can shoot some video. Guys, give me some critical questions for this particular MH to ask the owner when I go there.
Here are the most likely problem areas to check:
Tires are more than six years old or are cracked
batteries won't hold a charge
generator won't start
fridge/freezer won't cool properly
brakes and brake lines need replacing (due to corrosive nature of brake fluid_
fuel tank and fuel pump (that motorhome was built before ethanol)
shocks - due to age
handling on the highway
Make sure the generator starts right up. Once you get it started, check to make sure the roof air works.
Check the condition of the coach batteries.
Look for signs of water leaks inside and out.
Take a flashlight with you and check the chassis for rust. Check under the motor and look for any fluid leaks.
Check the plumbing in the motorhome. Make sure the water pump works, and there are no leaks. Check the hot water heater to make sure it works.
If you don't find a major problem, take it for a test drive.
Take it out on the highway and get it up to sixty and see how it handles. The steering should be tight, it shouldn't porpoise over dips, and shouldn't wiggle/waggle when trucks pass.
If you find problems or any signs of water intrusion, walk away.
Don't let the desire to own a motorhome override the logic of finding just the right one.
There are plenty of motorhomes for sale.
Examples:
http://tampa.craigslist.org/hdo/rvs/4079365419.htmlhttp://sarasota.craigslist.org/rvs/4073241020.htmlhttp://tampa.craigslist.org/hdo/rvs/4119108455.htmlhttp://tampa.craigslist.org/pnl/rvs/4075053003.htmlBill
