usersmanual
Sep 09, 2016Explorer
11178adm wrote:
defiantly get the codes checked, it sounds like it may be the variable geometry turbo is starting to stick, the turbo actuator has sensors and is calibrated to the turbo and if it does not respond to the ecm command the check engine light will light, the ecm keeps trying to move the vgt slide and if it moves as commanded the engine will respond and the check engine light will go out. hopefully it turns out to be something cheaper, or even under warranty
good luck and keep us informed what you find out
sounds plausible to me for sure. thanks
