MDKMDK
Aug 23, 2020Explorer II
Sydjohn wrote:
Thank you guys! We’ve had the refueling problem since we got it... so before we had to replace the fuel pump. It seems to be getting worse and it can take an hour or so to get enough gas in to fill the tank sometimes. I try to fill as slowly as possible.
I will look closer for a problem with the hose.
Thanks!
Sometimes rotating the pump nozzle 90 degrees clockwise or counterclockwise from vertical will make a difference.
I had a similar issue with my 2002 Roadtrek, and it had to do with a lengthened and slightly more convoluted path for the fill pipe, from the fill port to the tank. They had to modify the stock fill pipe to reach the repositioned fuel tank, so they could mount the generator.
Try it, next time you fill up.
38,782 PostsLatest Activity: Sep 10, 2026
